Hi Michiel, indicate the brand and model of the TV you are asking
If you have bought a new television and you have doubts about the installation or operation, if you contact the Technical Support, to clarify your doubts or needs
I hope you can solve the problem
Comment
Greetings Franco Dosil
Si has comprado un nuevo televisor y tienes dudas sobre la instalaci?n o funcionamiento, si contacta al Soporte T?cnico, para que aclaren tus dudas o necesidades
Espero puedas resolver el problema
Comenta
Saludos Franco Dosil
Here is a solution for your question:
1. Retrieving for a long time shows that you have low internet connection, so please reinstall your internet
(Roku cant able to receive sufficient network) and once again reconnect your Roku.
2. Even after that issue not fixed means. Please contact your internet service provider.
If you need any help related to Roku device visit this site https://www.rokucomlink.support/ to clarify your doubts.
Please clarify if u r able to surf other websites. Bcoz with ur question i doubt that u r still connected with internet. Are u using wifi or wired broadband?
Respectfully suggest you repost your query onto the FixYa motor forum 'cos this is for washing machine problems and I doubt anyone will be able to help you ;-0)
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
You might find the date of manufacture on the manufacturer's panel, probably at the back. Otherwise you will have to try contacting the manufacturer direct as I very much doubt anyone on the forum would have that sort of information. It's made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web.
John C
Be frank and open in your relationships because a healthy relationship means you must not cheat but discuss all matters openly be it personal or otherwise.
There must not be an instance of doubt on the partner as jealously is what makes is all to doubt. So clarify and move on if you think you like the girl to be one for lifetime and not for time pass.
Please note that the router WGR614v7 is a cable dsl router and will never handle ADSL connection. For ADSL connnection you need to purchase router model number DG834Gv5.
hi
there may be a problem with the connector that links the camera's cmos sensor to the phone's mainboard. Maybe it goot loose and now it's not making a perfect electrical connection.
Another possible cause can be the phone's firmware. However in both situation you will need to go to a service center to have them fix your phone. It's the safest and easiest way. If you do want that, I can assist you to dissasemble your phone to check the connections yourself but it will pe pretty hard without all the necesary hardware. Please post back for more informations if you need.
