What does the message "drum ends soon" mean? Should I do something?
SOURCE: message received drum life end soon
The message means the imaging drum is going to need replacement soon. The imaging drum and toner cartridge are the two main parts that need replacement sometimes. In some printers the drum and toner cartridge are replaced in the same unit, but the Brother has separate parts. The drum is rated for a certain number of copies, so as it gets close you get the message. Replacement drums are available at big-box office places and online. An original Brother is in the $100-$150 range and generics around half that cost.
SOURCE: BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE
To manually reset the counters, do the following:
(If nothing happens when pressing option, try using the back/clear button instead.)
SOURCE: drum en soon MFC 7340
The drum counter counts to 15000 then says replace drum soon. Just open the front door and press options. Select yes.
SOURCE: Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Testimonial: "thanks for your help...this is an awesome way to get help!.....although I didn't think to go online and look up the manual.but with dial up it's slow"
SOURCE: what does drum end soon mean?
1. replace drum unit
2. after replacing reset the counter - press "3" and "9" button at the same time in the ready state, the reset menu will appear on the LCD, select "DRUM" and press "ok"
resetting without actual drum replacement might damage your printer.
