To get the machine out of hibernation just press the power button.
Regards
The power button is basically used to come out of Sleep/Hibernation but you can also press Ctrl+Alt+Dlt. Further you can go to the 'power' by Right Click [on the desktop]--Properties--screen saver--power and then in the Hibernation option Uncheck the "Enable Hibernation" option and in the power schemes option "turn off harddisk" and "system standby" select never.
Hi, Your question is not clear.
If you need to remove Hibernate option,
Start-contoll panel-power options-Haibernate tab- Uncheck "Enable Haibernation" and apply.
or
If you are unable to switch on after haibernation check your Battery status. Connect the power and boot the machine.
