Casio CDP200 CDP-200 88 Key Contemperary Digital Piano w/ Stand Logo
Posted on Aug 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix a key with a weight issue - Casio CDP200 CDP-200 88 Key Contemperary Digital Piano w/ Stand
Tim Hofstetter
Level 3:
Genius:
  • Master 1,406 Answers
  • Posted on Aug 13, 2014
Tim Hofstetter
Master
Level 3:
Genius:
Answers
1406
Questions
0
Helped
378955
Points
4295
You'll probably have to take it to a Casio repair place, Matty. No weighting at all? Like... light tap gives you fortissimo?
  • 1 more comment
  • mattycee84
    mattycee84 Aug 13, 2014
    What happened was that the key got popped up hard from the front. So it stays popped up and feels/looks like the weight got shoved backwards. Wondering if taking apart myself is a good idea. Just looking for info on how to take apart and fix the weight?
  • mattycee84
    What happened was that the key got popped up hard from the front. So it stays popped up and feels/looks like the weight got shoved backwards. Wondering if taking apart myself is a good idea. Just looking for info on how to take apart and fix the weight? You can't push the key down at all
  • Tim Hofstetter
    Tim Hofstetter Aug 13, 2014
    Aaaah - I see. I was thinking pianissimo-fortissimo "weighting", meaning that the keyboard electronically detects how hard you struck the key and adjusts the generated tone's character accordingly. You're talking about a physical weight inside the key. You MAY get lucky and be able to tip the keyboard forward so the "noses" of all the keys point straight down, then lift that one key slightly to get the weight to slide back in place. If not, yep - you'll need to open the keyboard & manually remove that key to put that weight back into place. It shouldn't be terribly hard - there should be a bunch of screws inside recessed holes on the underside of the keyboard. Unscrew them all with the keyboard upside-down, and the bottom should lift off. You should then be able to unscrew the "guts" from the top of the keyboard and carefully lift it all out so you can get to that key.
2answers
HOW TO CHOOSE WEIGHT BENCH FOR ADULT
People with a skinny body long for well-defined muscles while others with obesity look forward to shedding the extra weight. One solution to all issues! A complete fitness arrangement is a key. A weight bench is, if not the most important a vital part of that arrangement, either residential or commercial. If you don't have one or are looking for having one, here are the precise directions to choose weight bench for an adult.
Adjustable weight benches
It has a traditional design with the ability to adjust as per your choice. This bench provides you with multiple work-out options, like- incline, flat and decline workouts. So, if you want to have a versatile weight bench that can be used to do various exercises, you can go for this one.
Flat weight benches
These benches are more straightforward and let you perform specific exercises. But it has an advantage too, that is it fixed and thus it is efficient to do exercise that requires stability. Its height is shorter than adjustable benches, but the bench also has a solid deck and easily movable facility.
Olympic weight benches
Olympic benches are well-known for their large size and built-in racking system. These benches can accommodate a 7-feet Olympic bar and a plate storage racking system to the rear of the machine. The built-in racking system makes the bench safer and eliminates the need for placing it in power of half racks. It has a downside too which is the fixed racking system which provides you fixed angle to exercise.
Specialist weight bench
These weight benches are designed to focus on assisting people to perform fixed categories of exercises, movement types or muscle groups as the benches are less geared towards all around versatility.
FACTORS TO CONSIDER
Comfort
You should check if the bench is comfortable. Weight benches are kept large and padded so that we can work-out smoothly. But it makes our exercise more difficult if the bench is not comfortable.
Numerical facts
You should know that recent studies have proved that a man who weighs 198 pounds, which is close to national average, jumps up to 175 for a novice and 215 for an immediate lifter. More precisely, the number is 290 pounds for an advanced lifter.
While for inexperienced women who weigh 165 pounds are a bench of 80 pounds or 95 for a novice. For experienced average weight women, the standard is 115 pounds 145 pounds for an advanced lifter.
Usage
One can choose weight bench for adult depending upon the number and manner of usage. For example, A person can use it for an occasional purpose (1 to 3 times a week), regular use (3 to 5 working sessions a week) and intensive use (average 1 hour a day).
Space
Your purchasing choice also builds upon how much space you have to accommodate the bench in your home or gym, and you should buy one according to the available space.
Installation
You should check how simple it is to assemble and disassemble the bench so that you can fold it and use it whenever you want even if you do not have adequate space to keep the weight bench.
Accessories and parts
The parts and accessories are also an important thing to check as it allows you to perform various work-outs. Sometimes, these benches come with extra accessories, but they cost more than the regular ones. So, if you want a budget-friendly weight bench, you should choose the regular benches over fully equipped benches.
Durability
The construction of a weight bench, if it is solid, can help you get a sturdy companion that serves over the years. Don't forget to check the warranty, though.
These are some of the tips and tricks you can use to choose weight bench for adult. We hope, we have provided you with enough information to make your selection easier and more sensible.
2answers
How to fix loose usb on Axiom 49 keyboard
Wow...just loose or intermittent as well? Most of these jacks and connectors are directly soldered to the main circuit boards which could mean broken and/or intermittent connection. Check your warranty status but if expired...to resolder check for a local electronics repair shop to help as the disassembly and intricate work may be beyond many DIY fans.
Can not turn 09 chevy cobalt off. Key will not turn to the left. Also difficult to remove key.
Do you have alot of weight hanging on your key chain? Your ignition tumblers are worn out. Replace the tumblers and it should fix it.
1helpful
I have Korg M3 with some weighted keys issues and I need top repair it. Please advise. Thanks, Ted
Hereis your service manual for the M3... 29Mb
http://elektrotanya.com/korg_m3_sm.rar/download.html
Scroll down the site page to "Get Manual" and click on it to download.
Be careful of the ribbon cables within the unit. God to have extra hands available when opening the unit.
We own a 2000 Subaru Impreza Sedan. It randomly won't start. The engine doesn't turn over. I can't remember if lights and radio work or not. it's very random though. We've speculated that it may be the...
if it's after market alarm system, (not the original factory instaled) then you're probaly right that would be the problem, or if you have aftermarket remote start instaled, they are causing many issue also.
or
ignition is not worn out is it? do you have lots of keys attached to ignition key ? (lot of weight can wear it out)
1helpful
2answers
Key won't come back up on Roland digital piano
Roland FP is a nice keyboard but has a known problem on cracking key weights. There is a counter weight under each key to push the key upward. There are two sizes of weight beams, longer one for white keys and shorter one for black keys. Roland did not make the original weight beams strong enough to last. They will crack and eventually break. When it happens, the key will stay down. Fortunately, they can be easily replaced.
Roland FP-8 has 4 black screws at the bottom on each side end. Remove the screws, flip the ends up and expose the interior. Near the hinge of the problematic key, carefully ply open the hinge tabs and remove the key from the hinge. You will find a weight beam under the key. Remove and inspect the weight. There should be a metal wrapped in a plastic beam. If the metal part is missing, find the missing part and replace with a new beam. You can order weight beams from Roland. It costs about $10 each plus shipping. Put everything back in the reversed order.
Oct 01, 2009 • Music
1helpful
My computer screen is stuck on hp logo nothing including key is responding
Try this partial soltion; it's worked for nearly everone who's tried it. Unfortunantly, you lose your wireless capabilities, but at leat you're not left with a $500 paper weight:
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
(It's interesting that the majority of posts with this issue have occured on numerous sites during the last two months).
Roland 3000 Digital Piano 88-Key Full-size weighted keyboard
It's not really for the faint of heart, but generally this is caused by gunk getting into the key circutry. Underlying the 3000's keyboard is a silicone pad with 2 contacts on it, the measurement between each being hit is the issue usually but yours just sounds like there's something in there causing a physical or contact obstruction.
What you really want to do is to remove the keys and clean everything but this isn't easy... You could try using 99% alcohol (from a pharmacy) to clean inside it which may well help you.
There's a good thread on a similar issue at:
http://www.electronicspoint.com/roland-hp-3000s-digital-piano-dodgy-note-t18946.html
Which may help you work out how to do the disassembly if you are brave, but I would start with pouring some alcohol in and poking it and hoping for the best 1st. It sounds crude, but it works amazingly well with some things.
Top Casio Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Casio Audio Player and Recorder Expert? Answer questions, earn points and help others
