SOURCE: nz500 will not open
i have encountered same problem. mine was done through removing the negative terminal of the battery for a few minutes. fix it again and problem solved.
SOURCE: my clarion VRX486VD will play dvds but not video clips
use nero vision this will work it does the same with mine
pls rate people arnt rating hope this helps
SOURCE: i have the clarion nz500.
Hi and welcome to FixYa!
As a first course of action please try this... Remove the positive battery connector and let it sit for atleast 5mins. then reconnect it again. This will reset the system and can get the unit back to it's normal operation.
Hope this helps and thank you for using FixYa! Have a good one!
SOURCE: Can I change the Navigation provider for the
You can get an update for the nav system from https://eshop.horizonnav.com/eshop/shop.php
SOURCE: Clarion NZ500 installed - will
Check if the yellow wire is connected to a 12 volt direct source,because this wire feed the memory back up of the stereo good luck
