Question about Clarion NZ500 Car Video Player
Clarion NZ500 nothing on screen
Hi everybody Hi have buy used Clarion NZ500 and I had trouble with screen... Radio works, CD works DVD works. Just cannot get the NAV display or any of the touch menus to work. Only brightness option appaers on screen and nothing else other :( I have done the remove battery for five min and that didn't help, try the button reseat didn't work neither Thanks for help
    New Friend:
Clarion ebrake safety bypass without using toggle switch
Clarion has a brake safety wire that has to switch from open to a ground every time you turn on the unit so therefore you cannot just ground the brake wire it has to switch to ground every time you turn on the radio
Posted on Aug 23, 2017
5 Suggested Answers
Anonymous
SOURCE: My clarion vrx935vD doesn't come out.
simple thats because you must have forgot to plug the small adapter in the back of the deck that has a yellow and black wire coming from it. if you have then one of those two wires are not hooked up to the right place. and if that fails then either u have a bad connection somewhere in ur car wire or in the inside of ur deck. i had the same problem when i hooked up mine i just forgot to hook up that adapter because its really small
Posted on Jan 10, 2009
Anonymous
SOURCE: clarion vrx486vd cd player wont open screen
help e find an installer for my hp dekjet 2300 series printer
Posted on Feb 16, 2010
kcarmax
Kevin Simoneau
  • 30 Answers
SOURCE: my clarion double din touch screen flickers from
Check to see if the orange or orange/white wire going into the Clarion is connected or not. Regardless if it is or not make sure the connection or non-connection is insulated properly.
Posted on Feb 24, 2010
rusty2c
  • 239 Answers
SOURCE: clarion vrx 485 vd.tuner works with amp but cant
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
Posted on Aug 19, 2010
xavierzx11
SOURCE: I have a Clarion NZ500...my
I have the same problem with my iphone4 (4.2.1)
Posted on Dec 01, 2010
Installed a clarion VX402A radio works and sounds great the only Clarion VX402A dvd / cd icon won't light up on the touch screen. Cannot insert dvd or cd
If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Jul 13, 2017 | Clarion Car Audio & Video
NZ500 with Sirius forgets presets
There is a memory keep alive wire that is usually yellow. It should be fused, it has either blown the fuse or had become disconnected.
Oct 09, 2017 | Clarion NZ500 Car Video Player
Nz500 will not open
i have encountered same problem. mine was done through removing the negative terminal of the battery for a few minutes. fix it again and problem solved.
Jun 28, 2010 | Clarion NZ500 Car Video Player
CD AND DVD NOT WORKING
Buy a new radio... The gears are fried... Wish I could have told ya some better news...
Nov 23, 2008 | Clarion VRX935VD Car DVD Player
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
Clarion NZ500 Car Video Player Logo
462 people viewed this question
Top Clarion Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
