Water remains in tub after wash cycle.
SOURCE: Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
SOURCE: GE frontload washer will not wash cycle or spin out
Thanks to Guest #2 our laundry is back in action and we're not waiting for a serviceperson. We took the front panel off, unscrewed the white plug and was sure our plastic drawer was open to catch the water, a load's worth. We found a small screw driver, 8 or so pony holders, some change, drill bits, bark, games pieces, can tops, etc... unbelievable. Thanks SO MUCH for the hint!
SOURCE: Fixing a clogged pump on GE Profile washer
waht u need to do is get a bucket now take the outlet hose and place it into it low to the ground if water comes out then it will be that your pump is faulty and needs replacing but if it doesnt the only way to do it is towels on the floor and with a low pan place this under the sump hose which should be in the middle of your drum which then leads to the pump pull slowly but not enough for the water to push the hose of do this until empty the only other way is to take it outside and pull the outlet hose of this is the quicker and dryiest out of them all but do do the first part to c if the pump is faulty m8
SOURCE: washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Vic
SOURCE: washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Testimonial: "Thank you MrBob. I will get the model number over the weekend. :)"
