SOURCE: OE message on our LG WM1832CW washer
I just was searching for the same exact error on my LG WM1832CW washer. From reading the other posts on different manufacturers I realized this was a pump clog issue for mine too. There is a small door near the bottom of the front of the washer and if you open that there is a filter basket. Once you start turning it and break the seal, the water will come out quickly, have 2 flat large tupperwares so you can catch the water. Once you clean out that filter it's good to go. A 5 minute job.
SOURCE: LE Error Code on Tromm
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Regards
SOURCE: LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
SOURCE: LG TROMM CLOTHES WASHER - "LE" ERROR CODE
I tried a solution I found elsewhere - worked great. I had turned my drum enough to cause the display to turn on (a glitch in their program, I think), then I got the LE code on the next cycle.
Unplug for 10 minutes. Turn back on and press the Rinse & Spin button, then set Spin Speed to No Spin. Run this cycle, which should work fine. Afterwards, you should be able to run your machine as normal. If this doesn't work, replacing the Hall sensor would be the next step.
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
