Suddenly the refrigerator stopped working even though there is power to it
Look how to repair Most of GE and Hotpoint Refrigerators. Here I replaced Evap Fan Motor, Defrost limit switch and computer board. Very often by looking at computer board u visually can see if its burned out, sometimes from back side of it one of the relay contacts burning out.
No. Look for failed evaporator fan motor or iced up cooling coil (evaporator) due to failure of component in the defrost system.
SOURCE: water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
SOURCE: Our GSL25JFPABS Side by side refrigerator door Water not working
water valve problem. behind the fridge. 3 or 4 screws .2 water lines. really simple.
