SOURCE: Where can I find my
Your tablet should not have an SSID. The SSID is the wireless network it needs to connect to. Input yours alog with the password (if applicable) and the tablet should connect.
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
SOURCE: serial number and snid number for an acer iconia
If you can see the screen partially you can get the code SN and SNID by the following route
Comment back if you can't get it this way.
SOURCE: acer iconia a500 tablet shuts itself off
This might sound a little stupid, but 1 is it plugged in when you put it sleep mode, and when u open the screen do you physically have to turn it back on. Sometimes when you put a computer in "sleep mode" and its not plugged in you lose power slowly
SOURCE: acer iconia is turning off when unplugged on full battery
There are two possible problems:
1. Software (Video Driver)
2. Battery
With regards to the software issue, you just need to update the video firmware or driver. Chances are, your acer is programmed to power savings mode when it's removed from the plug and when it changes the setting to power saving mode, the driver cannot support it because it's outdated that's why it goes off.
2nd Possible reason is your battery going dead. If that's the case, then you need to replace the battery.
I hope this helps.
Carlo
