Hi Friend, I am happy to assist you!
I understand you are seeking the location of the control board in your Frigidaire refrigerator. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the left or right side wall. With this information I can provide you the correct location. Thank you! - Z
Hello friend, thank you for your post!
From my understanding you have a replacement control board for your Frigidaire range and the power strip doesn't hook up properly so you would like to jump it over. I would not recommend doing so because you would be unsure what kind of electrical miscommunication that could cause. The part you have ordered maybe incorrect. If you can provide me with your model number I can double check your parts manual. You can locate your model number on the door frame of the lower drawer. I look forward to assisting you. -Matt
Thank you for your post, friend!
Based off the information you have provided your Frigidaire dishwasher is not getting power to the circulation pump. I was unable to locate any schematic for the control board if you would like you can perform a generic search online to see if that information is accessible anywhere else. I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this is helpful. -Matt
Thank you for your post, nansie Bento!
Based off the information you have provided your Frigidaire dishwasher is flashing "ER clean S". That error stands for a membrane switch failure, which means that your main control board has detected a key stuck or pressed in for more than a minute. You can push all the buttons down to attempt to locate the key that is stuck. It could be a potential issue within the keypad or main control board. You could try to clear the error code by resetting your appliance, which can be done by flipping the household circuit breaker for roughly ten minutes. Hopefully this is helpful. -Matt
