HP TouchSmart 300-1020 All-in-One Desktop PC - AMD Athlon II X2 235e 2 Logo
Posted on Jun 22, 2014
Why is color calibration not working?
One color bar in the display calibration for color no longer responds, and it is not possible to get white in new profiles. I have updated and reinstalled the display adapter driver several times. I have replaced the ATI Radeon HD 3200 graphics card as well, all with no effect.
Xavier Silvera
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Mar 08, 2016
 Xavier Silvera
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
6200
Points
60
Maybe it to os your using why you cant access it
5 Related Answers
John Sparozich
  • 357 Answers
  • Posted on Mar 20, 2009
SOURCE: HP D530 Video card upgrade
If the HP D530 has an AGP slot, which I think it does, then yes you can install the Radeon HD 4350 card.
Make sure you have the correct driver for the video card.
Go to this site for more info:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00059123/c00059123.pdf
Hope this helps.
Good Luck.
Anonymous
  • 34 Answers
  • Posted on Apr 30, 2009
SOURCE: ATI Radeon 9250 PCI card not recognised.
Make sure the slot isn't disabled either by jumper settings or in the bios, and the card is securely inserted in the slot. If these aren't the case, you have yourself a bad card, or a bad slot.
Anonymous
  • 15 Answers
  • Posted on May 23, 2009
SOURCE: installing ati radeon x1300 graphics card
try installing the drivers from this site: http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_vista32.aspx?type=2.4.1&product=2.4.1.3.7&lang=English
mattrubin
Matt Rubin
  • 161 Answers
  • Posted on Apr 26, 2010
SOURCE: New graphics card problems with my Presario SR5350F...
Make sure you plug in any auxiliary power cables are are required for the video card.
Is the card used. Has it ever shown signs of life?
Go into windows via integrated graphics and install the latest drivers.
After that I would go into your bios with integrated graphics and turn off intergrated graphics. Look around if there's like a setting that's like switch to PCIx graphics or something. After the restart try to use your monitor though your video card.
Anonymous
  • 702 Answers
  • Posted on Jun 25, 2010
SOURCE: My HP M7260n doesn't recognize my new Video Card...
You might need to uninstall the old video card device, so Windows does not use the old drivers for the new card.
Another option is to try and boot in Safe Mode (press F8 during startup), so Windows uses the VGA mode (which all video cards support), and then install the proper driver.
Installing the latest ATI driver updates might also not be a bad step.
CALIBRATE THE COLOUR TEMPERATURE IN MY LENOVO LAPTOP
https://forums.lenovo.com/t5/ThinkPad-Edge/Can-I-change-the-color-temperature/td-p/674445
https://forums.lenovo.com/t5/ThinkPad-P-and-W-Series-Mobile/Can-you-change-color-white-temperature-of-the-display/td-p/4204703
Lenovo Community - Lenovo Forums
forums.lenovo.com > topic > findpost
Sep. 15, 2015 - Re: Lenovo Y70 How to Change the Screen Color Temperature. 2015-09-15, 20:27 PM. Hi, I followed your instruction and the screen colors are ...
Apr. 13, 2015 - I tryed to adjust the color calibration through the interal display functions ... that you facing issue with display calibration in your Lenovo G50-45 laptop. ... Particularly the much too high color temperature that is seen in a visible ...
How are the calibration setting for UN60H7150
hears?
Samsung H7150 Calibration and Picture Settings 1080p 3D Smart LED TV by Robert Wiley, Senior Editor
The H7150 Series
UN46H7150 Review UN55H7150 Review UN60H7150 Review UN65H7150 Review UN75H7150 Review H7150 Calibration Notes: Calibration was very accurate and easy to aquire with the H7150 series LED TV. In fact, it is pretty close to the D6500 color temperature that our calibration shoots for. Be sure that you are changing the AutoMotion Plus feature settings depending on the programming you are watching. That is one of the most important things to keep in mind. With most programming you will want to turn it off or at least the De-judder portion. With 3D really does see a benefit from this, so you may want to leave it on. The Color Space needs no adjustments for a good calibration.
A television in the process of being calibrated before we begin our review.
Post Calibration Picture Settings Picture Mode Movie Backlight Contrast Brightness Sharpness Color Tint G50/R50 PIP Off
Advanced Settings Dynamic Contrast Off Black Tone Off Flesh Tone Color Space Custom White Balance (See Table) 10pt White Balance (See Table) Gamma Expert Pattern Off xvYCC Off
Picture Options Color Tone Warm2 MPEG Noise Filter Off HDMI Black Level Low Film Mode Off AutoMotion Plus Off Smart LED Off Cinema Black Off White Balance R-Offset G-Offset B-Offset R-Gain G-Gain B-Gain
10pt White Balance Interval Red Green Blue
Screen Adjustment Picture Size Screen Fit
(Note: Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jun 30, 2014 • Cell Phones
2answers
How to adjust contrast
contrast is bundled with color as far as i can tell
you can search "calibrate display color"
or
go to control panel, either by going to windows start screen swipe up to go to apps and go to the catagory windows system(far right),or long tapping the window button on the bottom left of the desktop.
in control panel tap appearance and personalization and then tap display.
on the left is an option "calibrate color" mine has a shield next to it
follow the wizard
How do I calibrate my windows PC monitor?
To calibrate your screen you have to open the control panel by clicking on the start button then the control panel in the right collum. Type "calibrate display" into the search bar in the top right of the control panel window. Open the calibrator by clicking on "calibrate display color" you may have to have administrator permission to calibrate the screen. Then follow the instruction on the screen.
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
• Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
• On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
3helpful
2answers
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
1helpful
2answers
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
1helpful
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
Half of my touch screen on my LG Arena is no longer working, there is no reason for this. Can i re-callorbrate my screen any way?
if the other side of the screen responds correctly then it is calibrated correctly and it is a faulty screen. if not then for this model im unsure exactly how to calibrate the screen but it should be somewhere under settings and display
2helpful
Benq 7220 display wrong color
It sounds a lot like a bad color wheel if it was a DLP. IF it is a LCD then i would say one of the LCD panels is bad or possibly a connection problem that drives the panel or the connection that hooks up to the projector is suspect. Let me know if that helped you at all.It is strange that the bottom shows white though. Jay
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
