My pictures will not load onto my computer. When I plug my camera in, it says "The devide is not connected to the system. Connect the device and try again" It says there are no images found on camera but there are new ones that need to be on my computer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: Pictures won't upload onto camera
there is solution for viewing the other size files in ur camera sir.
because camera is designed to read only that size of images.
SOURCE: My computer does to respond to the digital camera for downloads
If you can't find a driver (and you haven't said what sort of camera this is) you may need to get a card reader. These are inexpensive, and can be bought very cheaply (about £5.00) from dealers such as 7dayshop.com. Make sure what you buy will accept your type of memory card (eg SD and SDHC are not the same thing, and many older/cheaper card readers won't read the 'HC type).
If still struggling, try looking for the brand website. If it's Canon, this can be infuriating, but eventually you be able to find the driver you want.
SOURCE: CANNOT DOWNLOAD PICTURES ONTO MY LAPTOP,
You need to download the drivers and software either form your install disk or the manufacturers site under "Support"
SOURCE: Cant upload photos from my camera
try this go into device manager, remove ALL the USB, uninstall all the drivers, reboot PC, install the software that came with your camera, reboot, at next desktop, wait say a few mins, and NOW plug in your camera, you should hear a dong dong, it will then either install or ask for drivers, point it to the software that you used to install, wait until finished and with it still attached, reboot, wait until desktop appears next time, and wait a little bit, now your camera should work.
