SOURCE: Watertap message on Bosch dishwasher
Hi.
Check the water supply first. Make sure water is actually flowing through the tap. Also check the inlet hose has not been squashed on installation as this is a common fault. All hoses should be routed along the bottom of the machine in the back where clearance is provided.
Regards Sam
This code means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
· Press "Stop/Clear" to clear the display and stop the beeping if any.
· Reprogram the dishwasher.
· If the code still displays, turn off the power to the dishwasher at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on.
Thanks for using fixya
