SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
SOURCE: Compass in 3 parts on the screen
This is normal! The compass looks like this in "course pointer" mode.
When you're looking at the described compass screen, press the lower left button and notice the line "bearing pointer". When you select that line and push the front joystick, you'll notice that the compass needle is "normal" again . And when you push the lower left button again, you'll see that the line has changed into "course pointer". Pushing the joystick again toggles between those two modes. The shifted needle indicates how far you drifted from the course that your route follows. See page 31 of the English manual for details.
Jean-Marc Bouyeure
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
SOURCE: Bosch dishwasher soap dispenser
all you have to do is take a flathead screwdriver and look at the dispenser it has a locking metal around thecase where the dispenser goes. it a press in and listen to it click thats when you know that section is in.the plastic around the dispenser is the section where it snaps in. also unplug the dispenser. its only one plug in. very easy but atrick that i use is make sure the rubber gasket is lubricated with something like dish soap.when installing it you have to push hard and listen for the snaps .nyc appliance repair can handle at 1-888-692-1055 based in nyc
There
are three common problems that cause the Soap Dispenser or Cup not to
open. I have a tip that will explain these problems in
detail....
Dishwasher Repair Problem Detergent
Cup does not Open
heatman101
The symbol you're describing is saying the salt tank is empty. Normally on this model if the dispenser isn't opening it's because it's not heating, the dispenser is triggered when it reaches a set temperature
