F24 error code is key stuck error as the service manual of your product says (THERMADOR C302 SERVICE MANUAL Pdf Download ' ManualsLib) By replacing the faulty key or whole key board will revive the machine. As the model is discontinued/obsolete, a good service person can find alternatives to make it in working order.
If your Thermador CM302BS oven is beeping once every 30 minutes without any visible indication on the control panel, it's possible that the oven is experiencing an error or malfunction that is not being properly displayed. Here are some steps you can take to troubleshoot the issue:
Check the owner's manual: Consult the oven's owner's manual to see if there are any troubleshooting tips related to the beeping issue. Look for any error codes or messages that may be related to the beeping.
Reset the oven: Try resetting the oven by turning off the circuit breaker that powers it, waiting a few minutes, and then turning the circuit breaker back on. This can sometimes clear up temporary issues with the oven's electronics.
Check the oven's self-diagnostic system: The Thermador CM302BS oven has a self-diagnostic system that can be accessed by pressing a series of buttons on the control panel. Consult the owner's manual to see how to access the self-diagnostic system and check for any error codes or messages.
Contact a repair technician: If you are unable to resolve the issue using the above steps, it's possible that there is a more serious issue with the oven's electronics that requires the attention of a qualified repair technician. Contact Thermador customer support or a local appliance repair service to schedule a service call.
It's important to address any issues with your oven promptly to ensure that it is operating safely and efficiently.
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Hello, welcome to FixYa. Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display. Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately). In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units. Hope this helps move you forward. Let me know if I can assist you further and good luck.
The "F53" error code on your Thermador "C" series ovens indicates a upper door lock fault, makes sense since that is the issue you described.
Whether there is actually a fault with the lock remains to be seen. Here is what I`d suggest you try...
Locate the service panel for your oven ( should be an isolated 40amp breaker ) and turn it off for a few moments and turn it back on.
This will initiate the start-up sequence which activates and checks the controls and lock assembly, hopefully resetting it to the "open" position and subsequently eliminating the error code.
Let me know how that works or if you require further assistance.
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
