20 Most Recent Thermador SEC272BPSS Electric Double Oven Questions & Answers
After calling an authorized technician and the thermador support line, neither of which solved my problem, i was told a HARD RESET of the PROBE is all that is required. This problem originally occurred on my Thermador double oven after a power outage and rendered my oven unusable b/c the probe light would not go off -- even though i had never used the probe!
To hard reset the PROBE, turn off the oven at the breaker box, plug in the probe for 1 minute and remove it, then turn the power back on at breaker box, and probe light goes off!! Also, since i didn't have the original probe and to buy a new one would be $80, I borrowed a friend's Thermador probe (different model but it still worked). It cost me $85 for the service visit, 2 weeks of nonoperational oven, and about 5 hours time -- hence the reason i am making this post. It is a golden trick!!
What did NOT work -- turning off power to house again for 15 minutes to reset the OVEN, and disconnecting the probe wires from control panel so probe isn't recognized.
Thermador... | Answered on Jul 07, 2019
The F24 fault code is caused by a closed/stuck/shorted contact on the control panel for more than 60 seconds, such has someone leaning against the controls or objects hanging in front of the controls.
Solution: Touch OVEN OFF, or turn power OFF at the circuit breakers, wait 3 minutes and then turn it back on. If the condition persists the touchpad/control panel will likely need to be replaced. Turn the power off in order to stop the beeping.
Thermador... | Answered on Dec 21, 2011
Hey there again
sorry i got disconnected from the session
please try to reenter the session again
best regards mike
Thermador... | Answered on Nov 26, 2009
I just finish doing the same thing and you have to be carefull in putting back the panel the same way it was set, otherwise it will not work. Just do it carefully and you should be able to tell when is set in place correctly. Do not use force, since it was designed to be set in one position only before attaching the screws back in place. Good luck!
Thermador... | Answered on Apr 08, 2008
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
Thermador Ovens | Answered on Aug 08, 2019
Gave you an F? Give it a "Y" back!
Sensor panels cost more in parts and materials to replace than a new unit!
Thermador Ovens | Answered on Jun 24, 2019
Time to buy a new over bub... you don't want to blow your house up!
start from the beginning, how many circuit breakers did you turn off? how many did you turn back on after the repair?
Thermador Ovens | Answered on Jun 10, 2019
Thermador SEC272BPSS Electric Double Oven Logo
Popular Tags
7 questions posted
Top Thermador Ovens Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Thermador Oven Expert? Answer questions, earn points and help others
View Most Popular
Thermador Ovens
  • Thermador Ovens
Most Popular Question
probe light stays
  • Ovens
