Question about Thermador SMW272 Electric Double Oven
Thermador oven door won't close all the way - seems like the seal is holding it open. I can press and hold it closed, but if I release, it pops out. The oven light stays on all the time. Model smw272
Posted by azalea4 on
alan727
    New Friend:
Have exactly the same situation. All the solutions I have seen talk about replacing the hinges or seal. But people report the same thing happens a month later. Looking hard at the door what it needs is something to pull it right at the top. So I installed a rare earth magnet from www.kjmagnetics.com I used part number BX884DCS which costs $4. It mounts with a couple of screws and I put it on the door a couple of inches down from the top.
Its possible that heat from the oven will kill the magnet over time but for $4 I can replace it for a lot less than hinges and it works great. The door closes more securely than it ever did when the oven was new.
Hope this helps.
Posted on Jan 26, 2011
  • Angelo
    Angelo Oct 30, 2013
    I just fixed mine for .50! It might not work for everyone, but my oven must have been leaning ever so slightly forward in the cabinet. I lifted the oven just enough to shim the front of it with 2 quarters. Now the door stays shut and the light turns off!
  • Alisa Padon
    Alisa Padon Feb 27, 2017
    I got the same magnets for my thermadore oven door that wouldn't close. It worked great for about a week and then the heat caused the magnets to completely stop working. It wasn't worth it for the short term fix.
halftank123
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Open the door all the way and see if it sits at 90 degrees. if it drops lower your hinges are most likely bent and will ned to be replaced.
Posted on Aug 06, 2009
  • Michael Vickery
    Michael Vickery Jul 23, 2014
    I just replaced the thermador oven hinges for the second time. The first time, I hired a repairmen to replace. When the door wouldn't shut tightly a couple of months later, I thought that maybe they just used bad parts. This time, I ordered them myself and replaced them myself. The door closed perfectly for about 3 weeks. Now, same problem again. Any good suggestions?
Curt
    New Friend:
The K&J magnet fix is awesome, with shipping now totals about $25. Don't waste time chasing web-sites for hinges which are not available. Magnets can be installed in less than 15 minutes without removing the door.
If you do remove door and want easy way to unlock hinges. Attach Visegrips for extended leverage, makes it very easy given the added length the Visegrips add to longest arm of the hinge.
Posted on Sep 07, 2016
  • Pieternjennifer Barnett
    can you elaborate on how you attached to door, seems to me a 1/4 inch magnet would kill the seal? TY
Door lock is stuck closed cannot shut door?
Good Morning Richard, thank you for your inquiry!
Based off the information you have provided your Frigidaire oven door is stuck closed and you are unable to shut the door. You can disconnect power from your range for at least ten minutes and that will reset your oven. This may trick your door latch into opening.
You can also hold down the cancel or clear button for 10 to 15 seconds that may allow your door latch to release. Also attempt to hold down the light and cancel buttons. I hope this information has been helpful to some degree. -Matt
Mar 23, 2015 | Frigidaire Ovens
I have a gmc275pd, and need to remove door to replace the inner glass. can't figure out how to remove the door, there doesnt seem to be a locking latch that others describe on the internet.
Open the door look at the hinge where it goes into the receiver you should see a small hole place a small short screw in the hole each side now close the door slowly hold the door while closing you should feel the hinges release out of the receivers, to take the door apart you are going to have to remove these screws to do this take the box end of a wrench pull the hinge back to take pressure off screw remove screw
Feb 11, 2015 | Whirlpool GMC275PD Electric Double Oven
Oven door won't stay closed, light on
If the door opens past the 90 degree level position, it means you need new door hinges.
Mar 06, 2013 | Thermador SM272 Electric Double Oven
I have the SC272TB Double Oven. The top oven is fine but the lower one will not stay closed. Whether baking or not, the door seems to pop open just enough to turn the light on. We walk by and press the...
Welcome to FixYa.
Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges.
Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Regards,
Macmarkus :)
Jan 26, 2011 | Thermador C302U Electric Double Oven
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
Mar 17, 2010 | Thermador C272 Electric Double Oven
The oven door (Model SMW272) does not close completely. It may need an adjustment or a new seal?
Generally speaking, if a oven door does not close properly, and it is a drop down door, then it usually due to weak springs in the hinges.
There is no adjustment provided, so the only solutiom is to replace both door hinges.
Please rate my nsolution.
Thankyou.
Jan 28, 2010 | Thermador SMW272 Electric Double Oven
Self-cleaning door lock is engaged and door won't close. How do I get door look to release so I can close the door?
I would first try resetting the breaker or unplugging the unit for a minute or two and see if that yield`s any success. If not...
Try holding the door switch pushed in.(or held closed in electrical terms) This may require a second person if you can`t reach the clock/timer while engaging the switch. With the switch held, set the unit for self-clean, let the lock advance to a "locked" position and once it indicates it is locked press cancel while still holding the switch closed. This should in theory force the lock to advance to it`s open/unlock position.
Hope that help`s. If so please rate the solution I provided.
Thanks for visiting fixya and good luck.
macmarkus :)
Dec 08, 2009 | Frigidaire Ovens
From door on range came off when I tried to lift up the range by the handle to slide it out. One of the hinges is hard to get back in place. There are two metal tongues on each side of the door. Is there...
Normally you force the hinges open and there will be a small hole to stick a nail in to keep them open. It is VERY hard to install the door if the hinges are trying to close it. You hold the hinges out with the nail while you install the door, then release the hinges to close by removing the nails.
Aug 11, 2009 | Thermador Professional Series PO301...
Thermador SMW272 Electric Double Oven Logo
8,441 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Ismael Rodriguez...
Charles Tidwell
Are you a Thermador Oven Expert? Answer questions, earn points and help others
