Question about Thermador Ovens
Thermador SC302TS starts to beep after cool down on every use of the upper oven. Error Code displays as "F-". Can only silence by opening oven breaker. What components would need to be replaced?
Posted by Michael Butler on
Terry
  • 11,347 Answers
Call toll free phone number for manufacturer for assistance shown at link below:
https://manualzz.com/doc/2114633/thermador-sc302t-electric-double-oven---user-manual-sc272...
Posted on Jun 30, 2020
SC302TS. Why won't oven heat?
If it's not the thermal fuse, it is often a control board failure. These boards are no longer available from the mfr but can be rebuilt at:
http://www.fixyourboard.com/boards/14-38-901.html
Often the relay boards need work too. We can rebuild these as well. Just contact us at FixYourBoard 512-355-1108
Aug 11, 2015 | Thermador Ovens
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
Our Thermador oven starts to beep when you shut it off and the way we are getting it to stop beeping is to set up a fan in front of the open oven to get it to cool. This stops the beeping after 10 m
Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
Oct 14, 2014 | Thermador C301U Electric Single Oven
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
Thermador oven sc272t f-c code I have a F-C code on the oven and it beeps continunually. Do I need to call a repairman?
Hello, welcome to FixYa.
Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display.
Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately).
In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units.
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 23, 2011 | Thermador SC272T Electric Double Oven
Error F5 comes on when trying to bake
Ok, this is a control fault that may or may not be solved by initiating a hard reset. To initiate this reset, you will have to unplug the entire oven for 3 total Min's. it is vital that you allow three total Min's before you power up once more. if you cant reach the actual plug, you can shut of the appropriate circuit breaker as well for three total Min's. Once the hard reset has been initiated, power the oven up once more. If the same problem still exists, you will have to replace the Electronic Oven Control Board.
Please rate and god bless:)
Apr 03, 2009 | Thermador SC302T Electric Double Oven
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
21 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Ismael Rodriguez...
Charles Tidwell
Are you a Thermador Oven Expert? Answer questions, earn points and help others
