If your printer powers up properly and the cartridge carrier moves back & forth than your inkpad needs to be changed. Epson estimates after a certain time of usage that the waste ink gathered in the pads are full. Just goggle for a resetter for your particular print. Its a simple program that overides this restriction set by epson. This is a feature put by all printer manufacturers to prevent the waste ink to to overflow on to the table. you can print now but If you are familiar with tools I suggest you open the top cover and soak up the waste ink with tissue paper (lots).
The 00010014 error code indicates that the Ink System Pressure Sensor reports low pressure.
This error usually is caused by an Ink Cartridge that leaks pressure.
thanks for rating
SOURCE: Epson Service Call Error 00010007.
"00010007 - CR motor out of position time-out error - Replace the board assembly, main"
Basically it means you need to contact an authorized Epson service provider. But you probably already knew that.
SOURCE: EPSON 9800 foutmelding SERVICE CALL ERROR
did you used a non-original ink cartridge? if you did your printer says"ERROR 0001001B" is print head error. need to be replaced, send to repair.
