20 Most Recent
Epson Stylus Pro 9800 InkJet Printer Questions & Answers
Maintenance request 0040
Maintenance request code:
The pump counter is near end of life, replace the cleaner kit ASAP.
This is what 0040 means.
Hello
I have replaced ink to the printer and i
Many of the Epson printers ink cartridges have a sensor thatallows the printer and the associated software knows when to replace theprinter ink cartridges (even when the cartridges have ink within them) and whenthe printer needs to be cleaned.
You mayreceive error messages if that sensor is faulty. In that case you shouldreplace that sensor.
Hope this will help you. Good Luck.
Service Call Error - 00010005
This error 00010005 popped up when I was messing with my Print head for cleaing purposes.when I put the print head back into place the lever mechanism that is attached to the cutter blade detached from itself not allowing the printer to move the print head freely.below is a picture I scanned in from my Quick Reference Guide that shows how the mechanism should be. When I saw this I then realised what had happend and was able to put down the cutter blade to re attach the lever mechanism. After this I did not recieve the service code again and the print head was able to move freely. I hope this helps.
Epson 9800 Cleaning Unit Replacement
you don't need to replace any thing just before on your printer press and hold Down, Right and enter buttons on printer panel and than on the printer after on leave the pressed buttons its show a new menu on it press down on adjustments and than enter again press down on counter clear and than enter again reset it than restart printer. thanx
Epson Stylus Pro 9880 Does Not Print
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Epson Pro 7800 Maintenance Request 0040
Hi Frank,Please supply a detailed description of the problem. Give as much details leading up to the problem as you can so that I may understand what's happening.I'll be waiting for your response.Randy
