SOURCE: The copier keeps saying to put doc. feeder down and i it is. I ha
When you lift/ open the ADF you should see a tab in the back corner (slightly in from the corner) of the ADF. This tab is for the machine to see that the ADF is closed. Make sure tab is there. On its sister model they used a depression switch, check that and make sure it is there and working properly.
SOURCE: copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
power supply has the fuse open that feed the voltage for the ardf
SOURCE: I'm getting a
On the rear left side of the copier there should be a black hinged actuator sticking up out of a hole in the panel, directly opposite of that there should be a white plastic tab that pushes that actuator down. If not try taping the actuator down flat with the cover.
SOURCE: We have a Toshiba E-studio 255. When we use the
just clean the right area glass ( the width narrow rectangular glass area ) at the right top glass.
