Question about Toshiba e-Studio 350 Copier
I have a toshiba e-studio 35. When copying through the feeder a line appears on the right side of the copy. Techs dont know how to fix it.
Posted by rwhick on
Edwin Martens
  • 1,110 Answers
"Normally" that is a simple problem. If it copies clean when you lay your original on the glass......but when using the Automatic Document Feeder (ADF) the copy has a black line then it is clearly something in the ADF scanner. Some machines use a strip of glass that is next to the large glass to scan originals when using the ADF. That strip of glass has to be clean top and bottom. Some models use a scanner in the actual ADF. Either way if it copies fine from the glass, the rest of the copier is eliminated from being the cause.
Is your machine under maintenence contract? Then I would keep calling them until they FIX it!
Posted on Oct 22, 2009
Why I get lines on my photos jpeg
If lines appear when scanning/copying from document feeder only, you need to clean the narrow scan glass located to the left of the main glass. If lines are present when printing, could be a drum/developer problem.
Oct 06, 2014 | Toshiba E-studio 2500c Color Copier...
Line is coming in copy ,while taking photocopy line is coming on the photocopy page
If happens only when using doc feeder it is a spot on small glass on left below doc feeder. clean it well
Feb 10, 2014 | Toshiba e-Studio 161 Copier Copier
Why is there still a line showing through middle of pages when scanning/printing via top document tray of toshiba e stuido 351c? I know who to clean glass area but not top tray.
Does this line appear when you try to print to the machine? Or when you make copies on the scan bed? If so, then you most likely have a mark on the drum unit. If not, then the **** glass that the document feeder uses is located to the left of the large glass surface, attempt to clean that and ensure that no mark or scuff marks are on the **** glass.
-David.
Nov 05, 2010 | Toshiba COPIERS E-STUDIO 3100C Copier
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
Apr 07, 2009 | Toshiba Office Equipment & Supplies
Toshiba e-studio 55 has 2'' wide black line on all copies
make sure the glass thats an inch wide under the doc feeder next to the large glass is clean if it is then you will probrably need drum or fusing rebuild
Mar 20, 2009 | Toshiba Office Equipment & Supplies
Toshiba e-Studio 350 Copier Logo
342 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
jasbo
jasbo
CheckitRight
CheckitRight
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
