SOURCE: non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
SOURCE: While playing a game, my
If holding down the power button for 10 seconds (theoretically, try holding it down for ages and be patient) doesn't reset your device, you may have to wait for the battery to run flat, then try the reset procedure again.
Hope this helps,
Alistair
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Same here
