Question about Dell Streak 7 Tablet Android
My Dell Streak 7 Tablet will not charge. When the charger is plugged in, it does nothing. No light at all. When the power button is pressed, the front lights come on momentarily and then the charging light blinks red about 3 times and then stops.
Posted by mslin812 on
  • 1 more comment
  • Anonymous Mar 17, 2014
    When I first got the nextbook tablet it charged properly but then it stop charging all together so I went and bought a new charger but it flashes when it charges and doesn't last as long on a single charge is their anything I can do to make it go back to charging right.
  • Anonymous Mar 28, 2014
    I connected it the usb charger and it wont charge. I connected it to my computer and it doesn't even read it. The power button flashes red when I attempted to turn it on or get any response. Any help will be helpful.
  • Anonymous Mar 29, 2014
    I plugged my chorded charger into vivitar camelio tablet USB/charge slot and it broke the charger. Can I get it replaced?
Anonymous
    New Friend:
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Posted on Sep 17, 2011
C.W. Schnell
    New Friend:
  • 3 Answers
Try charging some other unit (ex.mp3, cell phone) that uses a USB charger, but use the charger for the Streak 7 . This should let you know if it is possibly the cable. If the other unit will charge, this should rule out that the charger supplied with the Streak 7 is defective. Also check if the computer can "see" when the Streak 7 is attached to it by the USB cable supplied. If it can't see it, and the supplied charger from Dell isn't able to charge the Streak 7, it sounds like it is most probably the cable. The 30 pin cable is prone to break down. Currently on Amazon, one can be picked up for about $3-$4 Hope this helps.
Posted on Jun 26, 2013
  • amanda
    amanda Jan 08, 2014
    this solution isn't working
Santos Butial
    New Friend:
If you had a problem in dell streak 7 tablet not charging i can fix that 100% and i convert that to usb samsung.look for santy.in greenhills ,santy cellphone repair shop.
Posted on Jan 30, 2014
Emma
    New Friend:
Most of the time it's problems with the charger or the batterys, have you tried a hard reset? if you did you're best bet is too send it too dell so they can have a look at it. ^.^ hope this helps. <3
Posted on Jan 06, 2013
Brand new tablet will not turn on
Make sure it is fully charged. Hold power button down for about 10 seconds and wait if nothing comes up press power again for half a second. Still nothing? Then put it on charge, it should show that it is charging with a light of a picture on the screen. If there is no sign of charging, wait about 3 hours leave the charger connected and press the power button again for about a second and wait for it to turn on or for the picture to show it is charging appears on the screen, (make sure the charger is on and connected) . Press the power button again for another 5 seconds and wait. sometimes it takes a little while to turn on, especially if the battery is very flat. Other things to try are check the charger on another device e.g. another table or a phone if you can and try another charger on the tablet if they are compatible, (usually the same plug is o.k, check the voltage is the same. most chargers are USB 5v). It may need a more powerful charger than most small phones,. you can try plugging the USB cable into a car charger or USB 3.0 port on a computer. 2 amps is common for most tablets. Apple may be different, hard to be exact without knowing brand etc.
If all else fails see the retailer
Why wont my dell streak 7 turn on
Hello.
You can check if the battery had somehow got out of it's place.
Also it may be a software related issue, as a fix you can first try to plug it using the usb cable to your computer.
Hope it helps
1helpful
2answers
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
1helpful
My Dell streak 7 will power up but will only repeat Dell logo continuously and not go to main menu
During power up try holding the power button for 20 seconds. Repeat this three times. If still not working, connect tablet to your desktop or laptop and scan it if possible. Last option is from the desktop or laptop you should be able to reset to factory settings.
My coby MID7012 isn't going to the home screen after I charged it. Its flashing coby over and over. But its not turning on. What do I do?
Sounds like you are in a "Boot Loop". Let's try to break the Boot Loop. Plug the device into the charger, then press and hold the power button for 60 seconds - make sure the device is OFF after the 60 seconds. Let change overnight. Next Day, unplug the device from the charger, then press and hold the power button for 30 seconds, wait 30 seconds, press and release the power button normally, the device should be out of the Bootloop.
My dell streak 7 wont charge
i can fix that pls.go to santy cellphone repair shop at greenhills shoping center
Dell Streak 7 Tablet screen configuration
it seems to have a reset button internally that might be worth a try. otherwise a full hard reset may be worth trying but that erases all data so backit up 1st. how to hard reset dell streak 7 hope that helps
1helpful
3answers
How can I fix the charging port on my Dell Streak 7?
Ok this is not a easy fix. The replacement port connectors are easy to get and cheap $4-$10. How ever they require that you are able to take apart the tablet unsolder the old port and then solder in the new one.
There are several places that will do this as a service but it ain't cheap. One place shows $299 for board repairs.
http://www.portatronics.com/index.php?cat=c295_Dell-Streak-7.html&XTCsid=vo7vc1f8r011l9e4p6e1bq34e3
If you search for "dell streak charging port repair service" you may find one closer or cheaper. It is possible that you can find a good board by searching for streak repair parts.
Make sure you know what replacement costs are for the unit. On some of these repairs you can come close to spending what you would for a new unit. So be careful about that.
Dell Streak 7 Tablet Android Logo
Top Dell Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
