To fix the error code P 01 -537 on a Riso CV 3230, you will need to reset the machine. To reset the machine, press and hold the Stop/Reset button for at least five seconds. This will reset the machine and clear the error. If this does not work, then you may need to perform a deep reset of the machine. To perform a deep reset, unplug the machine from the power source and then plug it back in. Allow the machine to go through its startup sequence and then test the machine again.
For Windows OS technical errors, the easiest way is to reach Windows technical customer service. They provide an instant solution and help for email setup and password related issues.
Services offered-
Factory reset windows
Restore Windows solution
Windows Password lost solution
Technical support for Windows 7, 8 and 10
Support for Windows XP
Windows update
Windows uninstall, install, reinstall
Fix corrupted windows
Windows BSOD error
Error code 120 is scanner home position sensor problem. If it's a recurring problem, here are some troubleshooting tips:
SOLUTION:
Turn the main switch off and on.
Check the wires between Home Position sensor and the SBU.
Fix scanner board or the SBU .
Check the wires between scanner motor and the scanner I/O board
Fix the scanner motor.
Fix the Home Position sensor.
Fix pulley, timing belt, the scanner wire,
Fix the carriage.
Title : E001 Error Code That is Not Resetable Error : paper jam When the machine powers
up the E001 error code is displayed but cannot be reset. (Note: The reset
procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR) Workaround
: In this case, the Main Power Supply PCB Assembly was replaced. The machine
was powered up and the E001 code was able to be reset. The part number for the
Main Power Supply Assembly is FM2-0260-000. Remember, if the fixing unit
circuitry has an open or a short, the code may not reset. Be sure to confirm
the fixing unit wiring and try resetting the code before replacing the Main
Power Supply Assembly. Canon USA, Inc. Systems & Technical Support
Division1-800-528-2830
Error code C4 is a fuser error code for a Sharp copier. You will need to reset the error code in service mode. You may have to fix the problem with the fixing unit before you can reset the code. You did not give a make or model of the copier you have. Good Luck
I need the color code for a Ford audio system j v a l l o v l 18 c8070 ABC real number 0 27747 I'm getting aggravated because you're not giving me no color code list
