Looking for codes for acoustic solution Tv codes
SOURCE: kingavon remote control rc81s universal remote control
To program the Kingavon Home & Leisure 8 in 1 Remote Control RC81S:
SETUP by MANUAL SEARCH
A: Power on the device that you want to control. If it is a VCR, it must be inserterted with a tape. *(This works without a tape)*.
B: Press and hold [SET] key and press the device key (TV1 etc) at the same time.
C: The LED will be on at the moment. Then release the pressed keys.
D: Press the [POWER] key again, then release it. The remote control enters into Manual Search Mode and the LED keeps flashing.
E: Point the remote control to the device, and then press the [POWER] key. See if the device reacts or not. If it reacts, turn to step F. If not, repeat step E (press the [POWER]) every 1 Second.
F: Test other keys, if they do not work good enough, return to step A.
SOURCE: IR remote 103781- Looking for control code for the INSIGNA TV
If you have tried locating your tv type in the back of the manual that came with the receiver and can not locate it then chances are that the remote does not ssupport your TV. You can try finding the code by doing a power scan as follows to see if one not associated with your tv will work: With the TV on press and hold the TV button on the top left of the remote until all buttons light up across the top. Now preess the small red tv button-the topTV button on the left of the remote should stay lit. Now press the channel up button slowly until the tv shuts off. If it does press the channel down button and then the channel up button. The tv should now turn on. If it has press the pound sign and release. The tv button will flash three times. Now try powering the tv on and off. You should be sucessful. Remember to put the remote back into SATmode. Thanks for using Fix Ya. Let me know if you need further assistance.
SOURCE: Need remote control code for Polaroid FML1511 tv for Directv RC24
0182 0173 0133 1019 1136 0029
