The message 'No Waste toner box' indicates the belt unit is not installed properly. To verify the belt unit is installed properly, follow the steps on this link:
If the problem continues, the printer may need service. The printer has a one year limited on-site warranty. If the printer is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the printer is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
The 9840 uses a WT100CL cartridge for collection of Waste Toner.
If you remove the Drum Unit then the Plastic Sheet (Transfer Belt) like thing the Waste Toner sits underneath this. Lift out the waste toner and replace it or put one in if it is missing.
Put the Transfer Belt and Drum Unit back in. Close the machine and away it goes again.
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
