Make sure you're using the correct power adapter or that the one you have is not malfunctioning. I've experienced Roland/Boss equipment blinking (and restarting over and over) when they are not receiving enough power. Sometimes even the resistance caused by too long of an extension cord can cause this to happen.
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
I have this problem with mine. I've did some research and with the boss br 600 this problem can arise quite often .it's caused by a faulty power diode apparently except in that case I've never heard ofrom the screen blinking at all (which my 1600 also does) I wonder I'd this problem can be the same for a br 600 as the br 600
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
