20 Most Recent Roland BOSS BR 600 8 track portable digital recorder Questions & Answers
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
Roland BOSS BR... | Answered on Jun 21, 2018
Roland BOSS BR... | Answered on Aug 29, 2016
Is the transformer you are using the original? or are you using one that you picked up. If it is not the original, you have to make sure that the voltage and ground on the plug matches what the unit needs. Some adapters reverse the + and - on the tip and sleeve on the plug.
Roland BOSS BR... | Answered on May 10, 2016
To be sure you need a schematic. You can actually take a look at it to see if is labeled or check polarity with a meter.
Roland BOSS BR... | Answered on Dec 22, 2014
rtm yet, read the manual on it for "troubleshooting" pages?
Roland Music | Answered on Jun 27, 2019
It's always possible the new battery had lost it's charge before it was installed. Check it with an ohm meter for it's voltage. Other than that, either the contacts in the battery holder may be in need of cleaning or the battery wasn't installed correctly.
Roland Music | Answered on Jun 06, 2019
You don't tell us where you're located, but the best bet would be either Ebay, Craig's List, or Reverb.com
Roland Music | Answered on May 21, 2019
Unfortunatly the impact from a fall can lead to numerous problems ranging from a broken fuse to a disloged power supply to a cracked board. I'd suggest taking it into your nearest Roland authourized service center to get it checked out. If you're not trained in electronics you can do more harm than good poking around inside the amp. https://www.roland.com/us/support/service_repair/service_centers
Roland Music | Answered on May 17, 2019
The most likely problem would be wiring. By dropping it you loosened or disconnected a wire.
Roland Music | Answered on Apr 30, 2019
Roland BOSS BR 600 8 track portable digital recorder Logo
9 questions posted
Top Roland Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Thomas F. Schneider
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
no power when switch 9 v dc transformer
  • Music
