Nokia N96 Smartphone Logo
Nini Tran Posted on Jun 23, 2009
Please help me...Battery is just going off?
Why did my Nokia N96 automatically turn off the power by itself, I have to charge it 2 times a day? Is it something wrong with the battery? I just got it few days ago. Even I don't use it, it's still going off. Thank you so much for anyone who helps!
Matt Tonning
Level 1:
  • Contributor 30 Answers
  • Posted on Jun 23, 2009
Matt Tonning
Contributor
Level 1:
Answers
30
Questions
Helped
11738
Points
58
Here is the Nokia website that might be able to answer your problems.
http://www.nokiausa.com/get-support-and-software/repair-and-recycle/repair.
2helpful
2answers
Nokia n96 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Why my n96 turns itself on and off
Hello bonganimutee,
if it's turning off because it's lacking battery power even after a full recharge, then you have a hardware problem that you need to get checked by a nokia care pint, it might be the battery, the charger or even the phone itself.
if on the hand battery power is ok, but the phone still turns off, then it might be a software problem. try to update/reinstall the firmware by downloading and installing nokia software updater from here:
http://europe.nokia.com/softwareupdate
"remeber to backup your phone contents using ovi suite"
another way to update the firmware os OTA, instructions are here:
http://europe.nokia.com/A41189822
if you feel that you can't carry any of the above procedures, please leave this to your nokia care point to do, you can find the nearest one to you through here:
http://europe.nokia.com/A4388379
i hope that will solve your problem
Thanks.
1helpful
My n96 16gb wont charge but battery charges in another phone
Hi, if you N96 is not charging when plugged to a power supply outlet and the battery charges in another phone, then it obviously means the charging i.c in the phone is bad thereby affecting the charging port.
You need to get the phone to a mobile phone repair tech to replace the charging i.c. Meanwhile you can use a desktop charger to charge your battery pending the time you fix it....
1helpful
2answers
My Nokia N95 8gb is turning off by itself and battery drying
I found this pretty interesting site regarding your phone problem. Seems like you're not the only with that issue.
Click here.
Hope this helps. Thanks!
Dec 22, 2009 • Cell Phones
I kept my n96 without charge for 2 days.after that its not getting turn on.
Your battery could have gotten drained completely. U have to jump-start its voltage level first. connect + and - battery terminals to a +3v dc supply for a short time (about 5minutes) then put back battery to phone. it should charge.
N96 wont turn on, when charged the naviwheel is on and screen...
Try a different battery on your phone and try this battery elsewhere to ruleout a bad battery (yours). Your battery could be dead.
2answers
Nokia n96 switch off automatically
hello
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
1helpful
6answers
Charging problem
how long have you had the phone? usually the longer you have the phone the more it uses battery. the same with cameras, laptops, etc... my guess would be that the battery is going bad. ive had a few phones for just a few months and the battery would barely hold a charge for a day. so try getting a new battery and hopefully that will solve the problem :). also make sure there arent any games or programs constantly running on the phone as that can also drain the power pretty quick. hope this helps!
2helpful
2answers
NOKIA N73 PROBLEMS
my n73 hand set problem is if i connect the charger on the screen displayed not charging, and i use to charge the battery charger to store power in battery. charger is working fine but hand set troubled me and the other problem is if i listen the music files after 2 minutes phone is off, in a day its happening lot of times give a complete repairing solutions.
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
