My nokia n96 is not charging after being full drained of power. when I plugged it to my charger it won't show me it's charging. i've pressed and held the power button several times and it won't even power up to show the usual white scree with battery icon indicator. any ideas on this issue and how to fix it? Thanks
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nokia n96 camra not sappotad
SOURCE: blank white screen
mudah tu caronyo ( it easy ) takan tombol barikut ko ( press followed button ) greencall+*+3+#+power button tahan (hold) sampai kalua formatting (until display formatting). this is minangkabau language
SOURCE: NOKIA 6680 DOES NOT CHARGE
well the problem is in your phone hardware,probably the "charging I.C". try to bring it on a service center..
SOURCE: my new nokia n96 has the message icon flashing non stop.
the message icon means that your sim card has old messages still stored on it. change your message storage location to sim card so you can view them, then delete them, and change it back..
as for not showing missed calls, beats me.
SOURCE: nokia n96 switch off automatically
hello
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
SOURCE: my nokia n96 slide is wobbly
This guy is full of ****! Go to this web site and learn !! http://www.simplysymbian.com/2007/05/02/how-to-repair-wobbly-slider-nokia-n95/ jasonlives2
