Two of the five drawers will not open. The handle release seems to work and the metal of the frame and drawer is not bent. On the opened drawers I noticed that there is a sliding clip on the right side attached to the drawer. It slides up and down into a slot on the rail of the drawer.
SOURCE: soap dispenser drawer jammed
Dear SK8RMOM,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: Detergent dispenser drawer stuck
You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
SOURCE: Dispenser drawer opening on WAH6700AWW
try take the drawer out and clean the inside where the drawer fits into. It may have a build up of soap/softener etc.. then give the drawer itself a good clean including the bottom of the drawer. I have this problem from time to time where there is a build up of soap etc...
SOURCE: the slide out drawer for detergent and softener
remove the lid of the washer. there are 3 torque screws you can either use a t15 or a 7 millimeter. locate the dispenser there are clips on the lid of the dispenser push in and lift up. be careful you will be able to get your drawer open. let me know if you need any more help
SOURCE: The drawer for fabric softerers is blocked and I
As you pull the drawer out there is a small plastic flap clip on the top or the bottom of the drawer that you just have to push down slightly and the drawer will come out. Some models do have these on the sides of the drawer so you may have to pull the drawer firmly to remove it.
