There are some very easy and quick steps that will help you to do a proper
Arlo Setup . You first need to install the
Arlo Pro 3 Floodlight Camera properly.
Kindly follow the further steps to
Setup Arlo Camera:
Open the battery compartment by squeezing the hook and pulling back tenderly.
Embed the battery as displayed and close the battery entryway.
Carry the camera inside one to three feet (30 to 100 centimeters) of the base station.
Sync the camera to the base station:
In the event that you are utilizing an Arlo base station, press the Sync button on the base station for around two seconds and afterward discharge the button.
Note: If you press the Sync button on the Arlo base station for a really long time, the LED under the USB image flickers golden for 10 minutes. While the USB LED is flickering golden, the sync interaction is obstructed.
Assuming you are utilizing an Arlo Pro 3 base station, press the button on the highest point of the base station for around two seconds and afterward discharge the button.
Sit tight for the sync status LED to squint green.
Press the Sync button on top of the camera for around two seconds and afterward discharge the button.
A blue LED on the camera flickers quickly to affirm sync.
In the event that the LED on the camera squints golden, the sync isn't effective. You should rehash the sync interaction.
Check the camera LED on the base station.
In the event that the camera LED on the base station turns strong green, the sync interaction is finished.
Rehash these means for every camera.
Note: If you don't finish the sync cycle within 60 seconds, press the button on the highest point of the base station and attempt once more.
Enter a proper key phrase to not face
Arlo Login Issue .
Hopefully, you will be familiar with how to install Arlo Pro 3 Floodlight Camera. Proper installation helps to solve
Arlo Camera Offline issues also.
