My car, an 07 Chrysler Pacifica, will not start.The battery is not dead and there is no noise when i turn the key.There is a lightning bolt with a line on each side. it dings five times in a row stops then there is one ding.
Here's a link to your lightning bolt dash light and what it means. Throttle Control Warning Light
SOURCE: program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
SOURCE: 2006 Chrysler Pacifica serpentine belt routing
here are a couple diagrams...
If you need anything else, let me know.
SOURCE: 2006 chrysler pacifica touring randomly
Its the connections to the battery. Have the SAME car (had 3 of them, actually), with the SAME problem. Any other weird things happening....or questions about the Pacifica.......I have become an absolute EXPERT, lol!
SOURCE: My Chrysler Pacifica tailgate won't unlock or open?
Check your fuses under hood above battery opens right to left
I we had that same symbol come up every day in the morning for about three months, we notice it after we did a spark plug tune up. I guess in our case...after my husband removed the intake manifold cover on our 4.0 AWD he forgot to to tighten the EGR pipe valve gasket, not the EGR VALVE it's self ...but the down pipe...After putting a new gasket on it the problem went away...so our guess in this case we had an air leak that caused this problem....hope this helps thanks!!!!
