No jams, oiled and cleaned.
SOURCE: air is leaking from around the trigger on model
first off it is dangerious,take it back to where you bought it, hopefully it is still under warrenty.
and if not find some repair shop to fix it for you.
SOURCE: I have just brought a
Rather than try to repair it or look into it, call the dealer or take it back to him as you will invalidate your warranty if you do anything to the unit, and that is not worth it. Let the dealer worry about it.
Most likely stuck driver or headvalve. Easy fix. Remove the head, pull out the driver and check for bent shaft, if ok, lube and reinstall. Next remove the valve within the head, lube and reinstall. Replace parts as meeded. Retest. If it still does not fire, could be that the safety foot is not pushing the firing pin all the way up into the valve. Easy to check. Remove the nails, remove the trigger to expose the firing valve pin. Dry fire the gun by quickly depressing the valve pin with finger. If it fires, adjust safety foot as needed. Parts are at www.toolpartsdirect.com
