Problems with connecting hp envy 6 laptop to dell 2100 mp projector
SOURCE: No signal on screen of Dell Projector 3200MP
start your laptop first then your projctor-if the problem still excit-press-control+f4 or control+f6 or control+f7
SOURCE: I have a Dell 2400MP projector and it does not
Try Pressing FN + F2/ If it does not work try with different VGA cable
SOURCE: Dell 2400MP out of range with vga connection
make sure that the resolution matches and that the laptop and the projector are both on vga and not composite. you can also reset the projector settings to factory default to start from the beginning.
SOURCE: Projector projects red screen.
My take on this...if that pin was *shorted* to another pin in the connector and not just bent, you could be looking at a damaged video input section. The pins in the video connector consist of the 3 color signals(red--green--blue), their individual grounds, and syncing. If this has indeed happened, which is *VERY* easy to do, the projector must be repaired by a service facility.
SOURCE: image is pink when you connect any laptop to the
make sure the input is correct. chances are you have it on component. change it to computer (rgb).
