Question edited for a lot more clarity. All question need full 'make model (what it is)' please as the first words in the question.
Question moved from Misc to Craftsman String Trimmer category.
Troy?Bilt Products
Rating: 3.7 - 232 votes - $99.99 - In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Troy?Bilt Products
Rating: 3.3 - 32 votes - $179.99 - In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
? 3:55
www.youtube.com/watch?v=fFt3a3St54U
Jul 9, 2014 - Uploaded by EricL5150
This is a video on how to replace weed wacker string trimmer line in a string trimmer/weed wacker. ... This is done on a Worx string trimmer but the process is pretty much the .... How torestring dual-sided spool lawn weed eater trimmer with ... Worx56volt Cordless Trimmer Edger Review & Demo Video ...
? 2:33 www.youtube.com/watch?v=8jEER8lHUQk Feb 22, 2013 - Uploaded by TheLegoCityBoys
How to replace line in a garden Line Trimmer. ... Ryobi 40-VoltLithium-Ion Cordless String Trimmer RY40210 - Real World Review & How To ...
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM
Head)
Use 2.4mm monofilament string. Use original
manufacturer's replacement string for best performance.
n Stop the engine and disconnect the spark plug wire.
n Cut one piece of string approximately 7.6m in length.
n Rotate knob on string head until line on knob aligns
with arrows on top of string head.
n Insert one end of string into eyelet located on the
side of the string head and push until string comes
out through eyelet on the other side. Continue to
push string through the string head until the middle
section of the string is inside the string head and
string outside the string head is evenly divided on
each side.
n Rotate the knob counterclockwise on the string head
to wind the string. Wind the string until approximately
20cm remains protruding from the string head.
INSTALLING STRING IN PRO CUT II STRING
HEAD
Use monofilament string between 2.4 mm and 2.7 mm
diameter. Use original manufacturer's replacement string
n Gather two of the pre-cut lengths of trimmer line provided
or cut two pieces of trimmer line, in 28 cm lengths.
n Insert the strings into the slots located on the sides of
the string head. String should be pushed in until
approximately 2 cm protrudes from the holes on the
top of the string head.
n Remove old string by pulling it from the holes located
on the top of the string head.
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Hi
check in you tube .
The video is talking about trimmer strings in general , but my experience is that all trimmers are more or less the same.
hope it helps
