Question about Cub Cadet RZT L42 42" 22HP Zero Turn Mower - 17ARCACS010
OIL LIGHT FLASHING BUT FULL OF OIL
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Posted on Dec 08, 2014
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
SOURCE: Cub Cadet Riding Lawn Mover with Kohler Engine -
you need to change your ,and if you already have,the light come on evevy 50 hours to let you know to change your oil, the light will go out after about 2 hours,there is a way to reset it in your owner manual, I just unhooked my battery and it reset
Posted on Aug 20, 2010
Testimonial: "Thanks much for very fast response. Don't remember seeing this in manual. Expect this to work. Was puzzling.,"
Your seering linkage needs adjusted. I try is first.
Find a free service manual to show you how.
Posted on Sep 01, 2012
May 10, 2018 | Cub Cadet Garden
Dec 02, 2017 | Cub Cadet Garden
Nov 01, 2016 | Cub Cadet Garden
Jul 11, 2016 | Cub Cadet 2012 - LTX 1046M - 22 HP Kohler...
Sep 21, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Apr 17, 2014 | Garden
May 25, 2013 | Cub Cadet Garden
Apr 08, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
May 20, 2010 | Briggs & Stratton Garden
10,046 people viewed this question
