20 Most Recent
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Questions & Answers
Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
9/14/2019 6:12:58 PM •
Troy-Bilt...
Answered
on Sep 14, 2019
Have a Troybilt 4 cycle weed eater. checked oil
Owners manual will state proper oil to be used but a good bet is that it requires SAE 30 wt. oil. Check and make sure no cooling fins are clogged with dirt, grease, debris, insect nests etc. Oil helps cool your engine also, but the proper amount is very important. I recommend synthetic oil for engine longevity. It's superior to standard oil for different reasons.
9/11/2019 1:54:31 PM •
Troy-Bilt...
Answered
on Sep 11, 2019
The bump knob on my
Believe you may have bad gears in item no. 17 would try replacing. To see this diagram go to partstree.com type in your model no. etc.
10/12/2017 3:59:21 AM •
Troy-Bilt...
Answered
on Oct 12, 2017
Oil type for troy bilt weeder 4 cycle model #
Non detergent, straight 30 weight.
Sometimes can be found labeled as "Tractor Oil". Otherwise, any premium 10w-30 I find in my experience with these stout 4-cycles to be just fine!
If breaking in engine from new, out of the box? Change oil with 10 hours on the clock with engine is still warm. You only need 3.2 Oz. to fill the crankcase!
So pour slowly. It is full when the trimmer is placed on a level workbench surface with the trimmer head dangling off the end. There is going to be a slight forward tilt away from the oil fill plug. Fill only until it just literally comes to the bottom of the oil fill plug with the trimmer laying flat on your workbench.
*DO NOT FILL IT UP WHILE HOLDING IT VERTICALLY!*
(I warned you. ;D )
Also at this time, clean and re-oil air filter and check your manual - these trimmers after break in require a valve lash adjustment. .005" @ TDC if my memory is correct....The manual I *think* states anywhere from .003 ~ .007 to be within spec. After break in, only need to adjust valves seasonaly. Regular oil changes @ 20~25 hours of run-time keeps them happy.
6/16/2017 6:43:09 PM •
Troy-Bilt...
Answered
on Jun 16, 2017
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
www.
troybilt.com/.../
troybilt/TB22EC-
trimmer
Troy?Bilt Products
Rating: 3.7 - 232 votes - $99.99 - In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
www.
troybilt.com/.../
troybilt/tb35-ec-curve-
shaft-
gas-...
Troy?Bilt Products
Rating: 3.3 - 32 votes - $179.99 - In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
12/9/2015 11:52:46 PM •
Troy-Bilt...
Answered
on Dec 09, 2015
Can not remove troy bilt weedeater head
Once all the bolts are removed, tap all the way around, (with a rubber mallet), where the head meets the bottom portion of the motor. It should come right off with a little coaxing.
Jim
7/3/2015 7:42:14 PM •
Troy-Bilt...
Answered
on Jul 03, 2015
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
5/15/2015 12:17:08 AM •
Troy-Bilt...
Answered
on May 15, 2015
