SOURCE: Error IPL on the Cash registar XE-A213
remove the Battery. Set the key in the PGM-Position and then plug the power cord.
Wait for the message "No Battery" and insert the batteries (with Poer On).
HTH Alex
SOURCE: Sharp XE-A203 software compatibility with vista 64-bit
to get the register to communicate with your vista or to even run the customer support tool software you will need to uninstall, reinstall, right click on the icon on your desktop, choose properties,in the compatibility box put a checkmark in the "Run this program as administrator",
everything should operate normal now with no errors
SOURCE: My Sharp XE A203 has ceased operation and shows
im several time face to this problem. i think this is common error.
turn on machine
then open the printer cover
open the battery cover
remove battery one by one
then machine display NO BATTERY
then put battery again one by one
then machine goes to the mulfunction.
display ***MRS***
turn off machine and turn on it
didnt came to normal condition press CL KEY.
thats over
but ua data is totaly lost you have to put all your data again
SOURCE: ipl for sharp cash register XE-A203 / XE-A213
MY NEW ELECTRONIC CASH REGISTER SHARP XE-A203 DSPLAYED IPL ON IT . WHAT DO I DO??
hmmmmmmmmmmmmm
press CL key ,didnt change display,
when power on & remove your batteries one by one
then replace batteries again one by one
display **** MRS *************** and press CL key
then machine came normal condition
but your data is lost.
reenter your detailss
