1999 car in USA?
Innova what model is it.? best is the one that does all FORD factory codes too. P1xxx UP,etc.
Innova, OBD2, scan tool (I have 2)
here are the steps,
1: fresh batteries in INNOVA 3x, AAA .
2: fuse that runs pin 16 power on OBD2, Power in not dead but is 12vdc or it fall fails. (car fuse for this pin not blown)
3: connect INNOVA 16pin plug to 16pin jack at knees dash edge
4: turn on INNOVA and scan . , the manual if free, if lost.
any scan tool , is best.
code reader are near useless, about equal to a trip to autozoned.
get a real scan tool and see it all, get one that can read
all factory Jeep codes.
i use an Innova 3160.
The code scanner that you need is called ODBII code reader with ABS, and it works in the same way as the one that you connect to the car computer module (ECU) to read codes when the check engine light comes on, but the cheap ones that you can buy from $50 do not have the ABS brake scan function.
If the problem is the ABS, then it is often a wiring to abs problem, or a defective ABS control module, a scan reading is necessary to know what the problem is.
