SIR I NEED HELP MY HP NOTEBOOK MODEL DV9205US/ DV9000 ONE YEAR CAN'T REBOOK, RIGHTS COMES BEEPS AND STOPS.
SECONDLY HOW CAN I BACKUP MY HARDRIVE. OR CAN A HP HARD DRIVE WORK IN A DELL NOTEBOOK?
Thank you
Henry
Had the same problems with my dv9205us in Feb 2008. Called HP and gave them the model and serial #s. There is a recall on certain models due to motherboard issues. The Fed-Exed a box with a return shipping label. Had the notebook back within a week at most with no cost to me at all. Give HP a call to see if you fall under the recall.
Dear All,
I have this HP DV9205US notebook for 18 months. Now it
won't start. Here is a important document from HP. You can verify
your notebook is cover by this recall or not.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01087277#identify
I call;
(800)474-6836 HP Total Care Worldwide
The guy told me that the recall is been cancel, he needs to charge me for the service;
I call;
(866)671-7362 HP Total Care North America
The girl told me that my notebook is under this recall and I still have 6 more months warranty. She will send me the free shipping label for the free repair service.
So, not all the people are bad. You just have to find the right one. Good Luck!
I contacted HP and after the warranty had expired, HP sent me a box with next day delivery and had it fixed. It has something to do with the bios board. They said that they overclocked the bios and it caused the mother board to over heat. They fixed the problem and sent it back to me at their expense. Now if you have the inept Microsoft windows Vista installed on your computer, you will have to reinstall everything on you computer. (HP will put you computer back to FACTORY SPECS) They are not responsible for any programs or information on your hard drive that you installed after you opened the box. Microsoft Windows Vista registers with the Mother Board in you computer to prevent people from pirating the program (as if anyone wants it any way). I hope you already have everything backed up and have all the install keys and program disks to get everything back into the computer after HP is done with it. This is why I will never do business with HP again, their problem created a hugh problem.
Simple solution...dont buy HP...along with Packard Hell, the worst computers on the planet
Thank you!
I have a DV9205US and was experiencing same issues as on this blog. Sure enough, chatted with HP and it's a recall. They are sending the box.
Replace cmos battery
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
I have the same problem.
Turn off computer and unplug hold down power button for about 30 seconds let stand for about 5 mins then plug back in and install battery and turn on.
Hope this helps.
My notebook does not initiate hibernation correctly after I added memory.
I have a dv9205us also. The factory had a recall for repoot problems. Under warranty there are keyboard adn boot up freeze problems due to mother board faults. I had to return twice to have mother board changed out then I upgraded to 2gig memory.
You can use a fast usb drive for memory using vista external drive boost facility. It will come on automaticaly and you can choose.
Make sure you are inwarranty but any way mother board faults were the problem for boot up. Freeze of programs and video failure on boot up. Also shutdown freeze due to not able to shut down programs. Be sure some program or utility is closing properly. Ther is a utility to insure programs do not stop other programs from running. Some programs demand that no other programs run. you can set most programs in utilitybut study it well.
that is my 10 cents.
TONY
For a quick cheap resolution I recommend a new motherboard. here is a LINK to that.
"ONE YEAR CAN'T REBOOK, RIGHTS COMES BEEPS AND STOPS."
Sorry, Can not help you.
Can you find someone to help you re-write your question that can use better English?
Is the computer still under warranty? You can you call HP for technical help.
-OR -
Have you tried hitting the "F8" key to reformat and reinstall(recovery)?
Start hitting the "F8" key as soon as the computer starts, repeat hitting the key until the computer shuts down, or goes into the recovery mode.
Am very sorry for my poor english, I meant that my HP NOTEBOOK MODEL DV9205US/ DV9000 is one year old and it can not start, when I turn on the power it runs for just 5secs and it stops. can I recieve any help?
When I power on my laptop, It starts and all of the lights come on. After that, the screen stays black and then the Laptop tries to restart again. It constantly goes through this process. You will here the hard drive trying to work and then two quiet beeps (not through the speaker). The Hard drive is good because I switched it out on to a friends computer. Can you help with this problem?
My Notebook does the exact same thing. The first 2 times I pressed the power button for ten seconds then restarted and it responded just fine ,the third time and every time after nothing, the lights come on then off then on, nothing else happens.
HP dv9205us, same, with or without battery, press power button, lights turn on for a couple of seconds then turn off, no sound at all.
screen stays black but buttons are blue and hard drive is working
My HP NOTEBOOK MODEL DV9000 is one year old and it can not start, when I turn on the power it runs for just 5secs and it stops. can I recieve any help?
MY computer is doing the same thing. Lights come on, computer try to boot but then turns off and starts again. Screen stays black.... It just keeps doing this and then shuts off after so many attempts. I tried to use a boot disk but that was also unsuccessful...
my name is kevin and I have the same problem whith you, my hp pavillon go of after 5second when I puy it on.
HP has extended the warranty to 2 yrs on these to deal with the problem.
Call HP and when you are lucky enough to get someone you can understand, they will go thru a trouble-shooting procedure with you, and if this doesn't fix it ( it won't ! ) they with send you a box and packing materials and pre-paid shipping label to send it for service. Now waiting on return of my notebook. Estimated 10 to 14 days.
Had my dv9000t for 14 months. It failed on startup, screen turned black, then did system dump, repeatedly. The recovery disc won't work, it had the same symptoms. Called HP support, the guy from India said it was the video card problem (256MB Nvidia GeForce Go 7600) and the repair cost would be $430.84. Is the problem really the video card? The HP support did not offer any assistance on repairing the Nvidia card. He hung up because I did not give him my credit card number.
I had the same problem...called HP & they said it was covered under the 'extended warranty', so they sent me a box and I sent my computer back to them. A few days later they called to tell me as soon as they opened it they saw evidence of water damage so they would not cover it under the warranty; the repair would cost me $900 and I had to give them a credit card number or they'd have to send it back to me unrepaired (total bs). I got it back, took it to have a new harddrive and motherboard installed. Now only 4 months later I'm starting to see similar problems to the last time this happened, and of course my repair is out of warranty. I've updated my bios, still my fan runs almost constantly, even with proper ventilation. Now, when it goes into hibernation, it will not come out. Instead, it powers on, fan runs, then powers off repeatedly. I will never by HP again...and it seems I may have to buy another laptop soon if I can't fix the problem b4 it gets to the same point as last time.
my warranty expired couple months ago u think guys they gonna fix it for no cost ?
Solution link . . . www.Laptop-Problem-Sollution.com.
