Frigidaire Professional Series FPDF4085KF Logo
Shane Doesken Posted on Mar 31, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the top of stove to get at ignitor module in FPDF4085KF
All of my igniters are sparking even when each of the switches are off. I'm assuming that the ignitor module is bad, but I can't get to it without removing the top of the unit... what is the correct way to remove the top of the stove?
  • Official Brand Answer 2,267 Answers
  • Posted on Apr 04, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1290106
Points
2557
Good Morning Shane,
I see that you are having trouble with your ignitors sparking while the switch is off, and are looking for instructions on how to remove the top of your Frigidaire range, model# FPDF4085KF. First, I do suggest, that for these kind of repairs, you contact a local authorized technician. Second, I don't necessarily have instructions on how to take that plate off, but I have listed below, a link that will give you a parts breakdown of your range.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995550513.pdf
-Best Regards-
WP
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
3answers
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
1helpful
2answers
When you turn on any burner on the spark igniter will stay on after the burner is lit and the knob is turn from the lite position.
You could of possible got the stove top wet causing the problem.This problem although sounds like your spark ignitor module went bad.
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
1helpful
Electronic ignition sparks continuosly (even when burners are off).
one of your electronic ignition switches is bad and burnt closed telling your spark module to spark
call applaince parts pro
1-877-477-7278
tell them u need part number
AP4101545 ignitor switch
18.00 dollars
they sit below the top under neaqth the selctors
you will have to go one by one
but the wires push in and pull out
5helpful
3answers
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 • Cooktops
3answers
Electronic igniter stopped working
I recorded video to let u see how its done. Problem Was : non of the burners would ignite (no sparks when knob is turned on). First sigh of bad spark module, but I got spark switches(they harness) as well just in case - One of the spark switches was bad - Check my video how I replaced them. Non of the screws was coming out.
Top Frigidaire Cooktops Experts
Mike Cairns
Mike Cairns
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
