Tip & How-To about Cooktops
GAS KITCHEN APPLIANCE CLICKING SOUND
Good Day,
Have you ever had that problem with your Gas Hob, Stove or Cooktop where you hear a clicking the whole time, coming from the ignition switches? Well, then today I will show you how to resolve the problem.
Why does this happen? Moisture on the ignition switches... Be it because of you cleaning it obsessively or, because you might have had a small water spillage - the causes could be quite a few things related to water.
Now for the solution (Please note: I will be using a General Electric Stove & Hotpoint Hob as demonstration, but this solution should work for most ranges - if not all)
Step 1 (Safety first)
Turn the machine off, switch it off at the mains if it is powered by it, and if powered by another source - Turn this off!
Step 2
Remove the knobs of the Hob/Stove:
If they do not come out, try to pull them as far out as possible, without breaking them. If there is a seal beneath them, then take it off as well - in the case if the knob does not come off, leave them be... If any grime or fat deposits are present, remove them with a damp cloth and some toothpicks.
Step 3
Get a hairdryer, or fan.
If using the hairdryer: Dry each knob area for 3 to 5 minutes for each knob respectively.
If using a fan: Put the fan facing all the knobs, and leave it there for 30 minutes.
Step 4
Leave the oven for about 20 minutes, and then re-attach the knobs and seals and re-connect it to power.
TEST, and viola! The problem is fixed.
I have attached a video to this Tip, that shows a complete yet simple solution to this problem (Kindly provided by General Electric):
Now you can use your Hob/Cooktop/Stove with no more annoying clicking sounds.
I hope this Tip has helped you, if it did - Please rate it.
Kind Regards
JEDEMEYER1
Cooktops Logo
ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Feb 22, 2010 | Cooktops
viking cooktop gas unit ignition clicks on all burners when I use
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
auto electric lighter for the gas stove no longer works
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
Nov 17, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
6,775 people viewed this tip
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
