20 Most Recent
KitchenAid 31 in. KGCS105 Gas Cooktop Questions & Answers
Gas cooktop problems
there is a part in the cooktop called a spark modual. it controls all the ignitors when it goes bad that what it does. replace the modual to fix the problem
Electronic igniter stopped working
I recorded video to let u see how its done. Problem Was : non of the burners would ignite (no sparks when knob is turned on). First sigh of bad spark module, but I got spark switches(they harness) as well just in case - One of the spark switches was bad - Check my video how I replaced them. Non of the screws was coming out.
Need replacement caps for Kitchen aid gas cooktop
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I have model # KGCT365X KitchenAid gas cooktop and
All four of mine did this.I glued it with a good quality super glue (don't get any inside or it won't fit back on)
Then I wrapped it many, many times with fishing string.Glue the end of the string after you cut it.Make sure that it holds.Then using alot of the super glue,spread/smear it all over the string.Its almost like fiberglass.Let it dry up real good over night.The first one I did almost 6 years ago and still holding.It's a lot guicker and easier then it sounds.
Burner caps
Call a local independent whirlpool dealer. they can order the parts from a supplier, and most do not charge sipping as sears a.k.a. A&E will. And they will usually be less expensive too.
