KitchenAid Artisan Logo
A
Anonymous Posted on Mar 27, 2014
Temperature dials steaming up
Overheating
1helpful
Steam iron not steaming was working ok one min then no steam
If the temperature dial is not set high enough, or the thermostat is faulty and setting the cut-off temperature too low, some steam irons will fill up their steam chamber in their soleplates completely with water and stop steaming, until the temperature returns above what's needed to continously generate steam.
Nov 26, 2017 • Irons
What is cause of temperature gauge indicating overheating and steam coming from engine and coolant leaking?
First off you are going to need a engine or a full rebuild if the temp gauge redlined.. The cause could be numerous things but if it was steaming from the back of the motor then it's either heater core hose busted or blown freeze plug.
Temperature gauge
When the heater goes cold and the engine starts steaming ,get it fixed by asking a local mechanic to have a look and maybe change the temperature sensor for you
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
1helpful
Main Oven Overheating
Try putting thermoter in oven take off main dial you well see a small screw ajust slowly and check every 30min.tell temp is correct.and put dial back on
1helpful
2answers
Temperature gauge doesn't go up but steam coming from under bonnet after a 5 mile drive red engine warning sensor light on
temperature gauge is not reading correctly and the car is overheating due to a leak or a blockage in the coolant system.
1helpful
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 • Tefal Irons
9helpful
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
6helpful
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
1997 jeep cherokee laredo
What does your temperature gauge say? Make sure you're not overheating. Steam is always an indicator that something is amiss with the radiator. Never open it when it's hot!
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
