Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill
the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are
dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam.
You'll see a little dark cloud-type icon with raindrops as opposed to a
white cloud with a stripe through it. The dark cloud represents moisture
(steam), and the white cloud with the stripe through it represents no
steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of
minutes while pressing the extra-long burst button a few times. That
should get rid of any impurities which can cause blockages. Try this if
the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum
temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the
soleplate isn't hot enough, the water won't turn to steam and will in
fact drip, spit or leak from the soleplate. Some Rowenta irons have an
anti-drip system, which will turn off the steam when ironing at a low
temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
SOURCE: Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
SOURCE: Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
SOURCE: Iron won't heat
send me manual on iron g1490
john reilly, 5640 hwy 14 w janesville wi 53548
asap
thank you
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
