Konica Minolta Konica Bizhub 652 Copier Logo
A
Anonymous Posted on Mar 26, 2014
Error code c 8106
Document feeder not working
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 14, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1914013
Points
11960
Something is preventing the tray that moves on the document feeder from going down
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Automatic Document Feeder jam error code with no visible paper jam.
Question edited for clarity.
No 'make model (what it is)' included! Although likely to be a printer, it could be a commercial document scanner. Normally, if something has happened to you, there will be someone telling you how to fix it.
Add make and model to this search query.
https://www.google.com/search?q=Automatic+Document+Feeder+jam+error
tip
Disconnecting the Xerox c2424 Document Scanner
The Xerox c2424 Document Scanner has a very high rate of failure. After very limited use it can generate an error code of 39,012.40 indicating that the document feeder is damaged. Xerox's answer to 99% of the document scanner issues is to replace the unit. But while restarting or cleaning can possibly resolve this issue, it is also possible to just disconnect the scanner and use it independently of the document feeder.
Xerox documentation however, does not instruct the user how to do this and tech support won't walk you though it. (So, courtesy of Pastor Ray of Indiana) Listed here are the steps to operating the scanner without the document feeder:
(1) Perform a standard shutdown on the printer.
(2) Disconnect the Document Feeder from the printer IN THE REAR OF THE PRINTER. You still need the side connector hooked up, the one by the power-on switch, power plug, USB port and all the other goodies.
(3) Power up the printer.
(4) It should work. However...
If for some reason the printer won't copy, then just do what I did in my experimentation:
(2) Disconnect the Document Feeder from the printer in the rear of the printer.
(3) Physically remove the Document Feeder, leaving the copy platen visible.
(4) Power up the printer.
At this point you should be able to copy stuff.
(5) Physically reattach the Document Feeder, but DON'T reconnect it!
You should still be able to copy, scan, etc.
on Apr 16, 2010 • Xerox C2424 Copier
tip
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
Konica c 452 error code c-f907
Main Board for the copier that receive info from the Document feeder is causing that code. Is your machine DS version or none version? Could have the incorrect document feeder for that machine, or the small printed circuit board that come with document feeder is bad. Could try a different document feeder. Might also see if you can have tech come and re-flash the copiers firmware specially the document feeder and or the MFB Board (Multi Function board) is bad.
DP760 Kyocera document feeder plugged in but not registering
1087 1087 then 906 turn off and back on if there is no problem with the dp 760 it should work fine
1helpful
Hello Miguel,
this error means a document feeder communication failure, so you need to check for 24V going to the document feeder control board. You should better call your technician
Hope this helps
1helpful
C0410 km1650 kyocera
A C-0410 error is a communications error between the document feeder and the machine. The manufacture did an update to the circuit board of the document feeder that sometimes corrects the error.
When I have had this problem it has been ether a bad harness or loose connection between the document feeder and copier or a bad circuit board on the document feeder.
4helpful
2answers
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
2helpful
2answers
What is happening when the Copystar CS-2550 displays the message "System Error Main Switch Off/On 0410?
The error code C-0410 indicates an communications error with the document feeder.
It normally indicates the cable between the document feeder and copier is ether has a loose connection or the cable has a short and needs to be replaced.
It can also be an issue with the document feeder driver circuit board or the copier engine circuit board.
I hope this is helpful,
Shawn
1helpful
Xerox Workcentre C2424 Error Code 39,003.40
That code it related to the document feeder or scanner.
What I would try is turn off the machine, then disconnect all the connectors from the scanner and document feeder, and espicialy the molex connector next to the power cord near the on off switch, that cable tends to work loose and is odd to tighten as it. Make sure you tighten that one well.
If it is scanner or document feeder related, there are almost no parts spared for those, the assemblies need to be replaced.
There is better then a 50 % chance the cables will fix the problem.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
