At first it sounded like the dish washer wasnt letting water to presure clean,it kind of glitched when it tryed and in the end did not wash the dishes completely. After that, the second time the machine seemed to work fine, but there was no hot water :( I was wondering what could be the problem? And also is there a test run available to check if the machine over all is working right?
SOURCE: code 20 water stays on the bothom in the machine.
Error Code 20 Indicates a Problem with Drain. You need to make sure that the Hose is not kinked.Then check to make sure that Pump is fine. Filters are all set. Then, you need to Check Pressure Switch to make Sure it is not Defective. If it is Defective, change it unless the last Solution would be main PCB. But, better to Inspect, Verify and Make sure before replacing any part.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Testimonial: "thank you helpfull but need a little bit more info "
SOURCE: No hot water in dishwasher or heat to dry dishes
I had this problem too, and was able to fix it. There is a generic
problem with AEG dishwashers of this type, caused by the bad solder
joint of a relay on a circuit board. Solution:
1. Disconnect mains power then open washer and remove the 8 or 10 screws
that hold the inox plate onto the door.
2. Gently peel away the inox plate and you'll have access to a white
plastic box at the top of the door where the pushbuttons are located.
3. Undo the 4 plastic clips on the sides of the white plastic box and
you'll have access to an electronic circuit board. Note the order of the
6 or 7 wire connectors along the edge of the circuit board and then
unplug them. The circuit board is now only held by a flat plexi
connector. Leave it attached.
4. Gently turn the circuit board over and look at the solder joints. You
should see one or more dodgy solder joints. Use a soldering iron and
some extra solder to redo the joints.
5. Put it all back together in reverse order to above.
This is a known problem (that no one knows about).
David.
SOURCE: The detergent tablet does not fall free of the
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
This is a 50870 aeg favorit dishwasher
